pacman110011 wrote:By the latest Internet Explorer, I meant IE7 Pro.
IE7 Pro isn't a version of Internet Explorer, but an IE add-on. As mentioned, you need to install and add-on like this to get spell-checking.
Formendacil wrote:Dr. J wrote:The latest version of Firefox has a built-in spell check. Like for instance, your name has a little red line underneath it right now.
I'm not computer-geeky enough to speak with authority on the subject, but my own experience is that using Firefox will also solve the time-out issue. At least, I know that while I would time out on forum posting back when I only had IE, I've never had that problem since using Firefox.
wobnam wrote:Formendacil wrote:my own experience is that using Firefox will also solve the time-out issue.
I assume most timeouts are simply caused by the user being idle on the forum for longer than the server-set timeout period. This shouldn't be affected by what browser you are using.
Formendacil wrote:(and maybe this is just a settings issue not a brand of browser issue) Firefox will save what you've been typing, if you hit "send" or "post" and it fails to upload. If you go back to the page you were typing on, your text should still be there.
