architect wrote:Ninja is Castles.
That is debatable. (and perhaps it should be debated again)
The floodgates open...
It has castles, covers a feudal society, and uses the Castles numbering system. Parts that only appear in the Ninja line are included in the current "Castles Accessories" minifig equipment packs. It would seem that Lego disagrees with your assessment.
See Lugnet Lego Set Database
LEGO > SYSTEM > Castle > Ninja. Strike two.
The basic argument against run:
1. The time frame is wrong. With muskets and cannon, that sets the Ninja universe at roughly 1600 AD give or take a few decades.
Rebuttal: That's an ethnocentric argument. Basically, it ignores that Castles existed all over the world and did not all start or end at the same time. It ignores that Japan was basically in a feudal age, and pretty much regressed in many ways after they reduced European contact following the Tokagawa ascendency. Because the Castle era essentially ended circa 1500 AD in Europe doesn't mean that the Castle era ended worldwide at the same time.
2. All the other Castles lines are limited to European Castles.
Rebuttal: A very weak argument - Lego isn't allowed to expand past the initial offerings?
3. The muskets are just plain counter to Romantic Chivalry.
Rebuttal: A more interesting and subtle argument. After all, technically there is nothing stopping Lego from tossing in firearms into Euro-Castles. They were around for 150 years of what is generally thought of as the medieval period. But what does Romantic Chivalry have to do with reality? The reality is that Romantic Chivalry for the most part is an ideal, a myth in many respects. The fact of the matter is that gunpowder is not an item exclusive to the Japanese feudal era regardless of whether Lego chooses to represent it or not.
4. Ninja doesn't mix in well with all my other Euro-centric Castles stuff.
Rebuttal: I understand the interest may not be there because of such, and if you want to focus Classic-Castle on the European aspects of Castles that's certainly a conscious choice that is up to The Classic-Castles Powers-That-Be (and opens up another avenue of debate separate from this one). But not liking Ninja, not wanting it mixed in with Eurpean-oriented Castles, and claiming that Ninja simply isn't Castles are different things.
Which is to say, if you want to stick Ninja in with "General Lego" because you don't think it matches the general thrust of Classic-Castle, that's a different argument. But if you want to say it simply isn't a part of the Lego Castles line, I think you need to make a case against a mountain of evidence otherwise.
