New Custom stickers idea
Commander Redbeard
Post by Commander Redbeard »
Since the circular shields LEGO makes aren't too compatable with stickers, I was wondering if it is possible to create stickers for the circular "Garbage can lid" which I often use in my viking sets. Could somone experiment with that since I don't have PhotoShop? Thanks.
Sitting in a midnight glade
Firelight dancing off burnished blade
A Forestman sits
Wondering about the next day
But after three mugs of ale
Let it bring what it may.
Bricksidge
Philosopher-King of the Gong Farmers
Post by Bricksidge »
Which of these do you mean?
armothe
Post by armothe »
I've tried......with some success. The problem is that all the discs/radar dishes are concave in nature. Thus a sticker cannot be simply applied. You will have to cut a slit along the radius - resulting in part of the design overlapping itself (on the other end).
Not to mention the shield design template will NOT be a circle. It will be more of an oval.
Sorta difficult to work with, but doable.
-A
TwoTonic Knight
TwoTonic of Many Colors
Post by TwoTonic Knight »
Bricksidge wrote:Which of these do you mean?
I presume the usage of "grabage can lid" matches my use and he means the rippled actual shield, not the kluged radar dish. Armothe is certainly on the right track with his approach for the radar dish - it seemed more work than it was worth, but hey, if somebody else bravely does the work!
The grabage can lid only needs a circle and a center punch. I'd only make it as large as the outer raised ring and leave the true outer lowered edge as a "rim".
armothe
Post by armothe »
I've tried to make stickers for the following:
I figured the first one was the "garbage can lid"?
I'll probably pursue this further at some point. Can't wait to create some designs for the Rainbow Knights Shields.
-A
