Barbrickian wrote:and I would warn you all only to use these with plain lego heads, or other heads you can sacrifice, since once the helm is on you probably won't be able to get it off again. I mistakenly put one on a bearded head and mangled the neck pretty badly with jeweler's needle nose pliers getting the head back out of the helm.
CastleLord wrote:Barbrickian wrote:and I would warn you all only to use these with plain lego heads, or other heads you can sacrifice, since once the helm is on you probably won't be able to get it off again. I mistakenly put one on a bearded head and mangled the neck pretty badly with jeweler's needle nose pliers getting the head back out of the helm.
I have the same problem with BrickForges Great helms and my tip is to put the head into a lego goblet and pull it works for me.
CastleLord.
JoshWedin wrote:My main beef with LA weapons is that they are attached to a sprue. I ruined the cross-guard on one of my long swords when I cut it off. Rather annoying.
Karrde wrote:JoshWedin wrote:My main beef with LA weapons is that they are attached to a sprue. I ruined the cross-guard on one of my long swords when I cut it off. Rather annoying.
I too have done this on mine.
Heir of Black Falcon wrote:Never had problems with that myself. How did you go about cutting them off? I find a nice razor blade is good. If you are really into it you can further clean it up with some super fine sandpaper. I never did model making or Warhammer etc. but have a friend who does and he seems to be able to get the connection points to be invisible. Maybe some of the pros or semi-pros can help out with their experience?
Heir
