Flesh-toned heads...
First, I am back temporarily. Does anyone know the username of the guy who spammed people, I may know him. Soooo, back on topic...
If minifig faces are just clear stickers on plain heads, has anyone tried/is it possible to remove the sticker on a flesh-toned head and stick it onto a plain yellow one, and if not, does anyone have a head decal template?
[img]http://uploadyourimages.com/img/112845eliotsig.jpg[/img]
- Lord_Of_The_LEGO
- Earl of Wells
Re: Flesh-toned heads...
Minifig faces are printed directly on to the plastic, they are not stickers. Yes, there is a template, but I have no idea where it is.Green Fox wrote:If minifig faces are just clear stickers on plain heads, has anyone tried/is it possible to remove the sticker on a flesh-toned head and stick it onto a plain yellow one, and if not, does anyone have a head decal template?
It isn't really a template, more of a size. You just find the center and work from there. Jamit and I use one, and here are the dimensions: 371 pixels by 71 pixels.
I am prett sure they are stickers. on some heads, particularly the newer ones, although it seems to be fairly random, there is a definite line, but I only think this is a sticker.
- Bricksidge
- Philosopher-King of the Gong Farmers
No..... I am pretty sure you are horribly, horribly wrong.Green Fox wrote:I am prett sure they are stickers. on some heads, particularly the newer ones, although it seems to be fairly random, there is a definite line, but I only think this is a sticker.
- architect
- Baron von Ellermann
Minifig heads have always been printed on with a machine. On the press release area of lego.com there should be a photo of a machine assembling minifigs and possibly printing the heads.I am prett sure they are stickers. on some heads, particularly the newer ones, although it seems to be fairly random, there is a definite line, but I only think this is a sticker.
The line you are referring to is from the shape of the mold. Also, as a general rule, if a LEGO set has stickers, they are not pre-applied for you. All stickers must be put on by you.
Ben E.
- Robin Hood
- wlister
I don't think a stickerd head would be stupid, but it would need a little more gentle care than a fig with the decal printed on. There are a few types of felt pen that work nicely to draw your own face with and that has been the best solution I have found. I also use an exacto knife to alter some of the heads to look more castle-like. No microphones/headsets in my castle realm.
- Formendacil
Thanks to you guys, I've found that erasers nicely modify faces to remove unwanted appendages. I should thank whoever mentioned it, the results were great.wlister wrote: I also use an exacto knife to alter some of the heads to look more castle-like. No microphones/headsets in my castle realm.
Maybe it was Nate.....
I think Bruce mentioned the eraser. Do you need to rub really hard and long to get it off?
- Lord_Of_The_LEGO
- Earl of Wells
Not me, I don't customize my LEGO (must -- must risist the dark side-- *gasp*)Formendacil wrote:I should thank whoever mentioned it, the results were great.
Yeah, I think it was Bruce...Sir Terrance wrote:I think Bruce mentioned the eraser.
Anyway, when you use a knife to remove the decal, does it mess up the minifig head and remove some plastic?
Must resist the dark side...!
I've written a faq on my website on how to best apply stickers onto a minifig head (from my own experience). It's located in the 'faq' section on the left hand column.
R. B.
visit my website: www.redbeanstudio.net
R. B.
- wlister
I have managed to scrape several heads with little or no noticeable damage to the head. It takes patience and a steady hand though. I may try the eraser idea myself, darkside would be easier to resist if the results weren't so great.Lord_Of_The_LEGO wrote:snipped...
- Formendacil
Must have thought it was you because I heard about it in connection to Harry Potter heads (the scar can be removed). I haven't actually used it for that, but the results were great for the Baron von Barron/Lord Sinister's scar.Lord_Of_The_LEGO wrote:Not me, I don't customize my LEGO (must -- must risist the dark side-- *gasp*)Formendacil wrote:I should thank whoever mentioned it, the results were great.
