Changing the Color of the Light in an LED (Light-up) Brick
Postby royalbrickcustoms » Fri Nov 15, 2013 1:48 am
Hey, does anyone know if (or how) you can change the color of light in a official LEGO light-up LED brick?
Any information would be greatly appreciated.
Thanks,
~RBC
"I can do all things through Him who strengthens me."
~Phil. 4:13
Royal Brick Customs Shop (Bricklink)
royalbrickcustoms
Re: Changing the Color of the Light in an LED (Light-up) Bri
Postby Sir Erathor » Fri Nov 15, 2013 5:56 am
I've often thought about this, but have no clue how to do so myself!
For the Glory of Loreos!
Flickr|MOCpages|The Brick Tavern
Image Image
Sir Erathor
Postby Crazycrownieguy » Fri Nov 15, 2013 6:37 am
You could probably create some sort of filter using colored plastic, or you could try replacing the LED in the light brick with the LED color you want to use.
CCG
For the glory of Garhim!!!
Captain Rufus Song
Crazycrownieguy
Postby AK_Brickster » Fri Nov 15, 2013 3:34 pm
Once you've changed the bulb, the brick would not be considered "purist" by most contests, so you're probably better off just rigging your own circuit with a stand-alone LED. I would think it would be a lot easier, and you wouldn't have to worry about ruining a perfectly good light-up brick. :)
Visconte des Paysans de Gong
Postby Buurli » Fri Nov 15, 2013 3:44 pm
AK_Brickster wrote:Once you've changed the bulb, the brick would not be considered "purist" by most contests, so you're probably better off just rigging your own circuit with a stand-alone LED. I would think it would be a lot easier, and you wouldn't have to worry about ruining a perfectly good light-up brick. :)
If it somehow would be possible to open it without destroying all the stuff inside, then you could also change the batteries :D. I have 3 old ones from the exoforce sets, which don't shine a lot, they really could use some more power and colour :).
I might start experiencing with this, as I have 3 light bricks with almost empty batteries... means I can try it 3 times.
EDIT: I got it at the first try. That was quite simple... if anyone wants instructions, then tell me and I will make some if I find time.
Buurli
Postby royalbrickcustoms » Fri Nov 15, 2013 5:14 pm
Awesome. I'd like some instructions please.
Were you able to change the color of the bulb?
~Phil. 4:13
royalbrickcustoms
Users browsing this forum: Google [Bot] and 2 guests
