plums_deify wrote:
3. This will be a Vignette. No larger than 12x12 studs. Please keep the base non-SNOT, so we can see the studs. No more than two levels.
Just to clarify, are we allowed to tile our base? The base would be non-SNOT, but you wouldn't be able to see the studs. You would, however, be able to verify the size of the entry by counting the tiles.
Also, with what I had in mind, you would be able to count the studs along two sides, i.e. I could leave the tops of the two 'walls' unstudded.
I hope I'm not being difficult. I'm just confused about whether you want the base to be non-SNOT because you want to be able to verify the size of the entry or because you want to see studs for another, more aesthetic, reason.
If you say no tiling the base then I won't tile the base.
