The Time Twisters Contest
Re: The Time Twisters Contest
Postby marakoeschtra » Mon Feb 22, 2010 10:58 am
Some great entries so far! :D
Here's my castle-ified version of set 8970, Cyclops Attack!:
Last edited by marakoeschtra on Tue Feb 23, 2010 10:22 am, edited 1 time in total.
marakoeschtra
Postby Aliencat » Mon Feb 22, 2010 1:08 pm
Just as a heads up: you've got a little under a week left to enter!
I'm really digging the amount and quality of entries so far! Keep 'm coming! :D
Aliencat
Josh's Minion
Postby sparhawk » Mon Feb 22, 2010 3:51 pm
Hello All,
My first post here, I hope you like my entry for the Time Twisters Contest, this was the reason for me to finally register here on Classic Castle after some time of reading every now and then. I hope you like my entry. I have attempte to castlefy technic set 8250, the search sub. To make the sub as real as can be in castle times, I have changed a few things from the original design. The grappers are operated manually by the driver of the sub and propulsion is also manual labour, in the back are 2 castle figs working hard turning the drive shafts for the 2 propellors. And because there is no compressed air, there is a snorkle that should provide the sub with air, which means the sub can't go to deep. The last thing that had to be changed was controls for going up or down, because it is a bit hard to use balast tanks that can be pumped full of air to rise or flooded with water to go deeper, the castle sub uses fins to go up or down, by changing the angle of the fins.
I tried to design a few technic bits in the sub, because technic is something I also like. The propellors can turn and the angle of the side fins can be adjusted, all from the inside.
Here are the pictures:
The original set
My version of it
Links to the pictures on brickshelf:
Back view: http://www.brickshelf.com/gallery/sparhawk/Castle/CCTimeTwisters/back_view.jpg
Front view: http://www.brickshelf.com/gallery/sparhawk/Castle/CCTimeTwisters/front_view.jpg
Inside view: http://www.brickshelf.com/gallery/sparhawk/Castle/CCTimeTwisters/inside_view.jpg
I hope you like it as much as I do.
Greetings,
Han
sparhawk
Postby Balamorgineas » Wed Feb 24, 2010 9:34 pm
Great contest!!! :D
Here is my first entry, Armored Bear rider
It is a twist on set #7708 http://www.peeron.com/inv/sets/7708-1?showpic=5681
Here is the folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422044
And here is my second entry, Fortified Pizzeria
It is a twist on set #6350 http://www.peeron.com/scans/6350-1/1/
Here is the Brickshelf folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422045
This was an interesting set to twist because I don't actually own any Lego Pizzas myself. I changed it a little so I could put the ingredients to make a pizza on the counter and stuck in a makeshift one for the delivery boy.
The backgrounds of the pictures are also weird. This is because I was experimenting with natural lighting and did not feel like doing a lot of photo-shopping.
Again, this is a great contest and I wish I started building sooner. :(
Thanks,
Balamorgineas
Image Image
Balamorgineas
Balamorgineas
Postby ChrisZ » Thu Feb 25, 2010 9:53 pm
Hello everyone... new to the board, and new to building with LEGOs after quite some time... Anyways, here's my submission for the Time Twisters Entry, a Medieval Take on Set 8970, "Robo Attack".
Here's the image bigger on Flickr: http://www.flickr.com/photos/lego_chrisz/4388214585/ (Best viewed in Full Size)
(Inspiration for the barrel-technique came from LEGO builder "TooMuchCaffeine")
Hope you guys like!
ChrisZ
Postby dip » Fri Feb 26, 2010 7:49 am
Here goes nothing. Because their is was way to little TECHNIC in medival times it is time for a remake of the 8435.
Here is the impoved version; a 1 TP (troll power) 4W pick-up truck. With additional troll powered winch in the back.
dip
Postby €quuïɳox » Fri Feb 26, 2010 3:40 pm
€quuïɳox
Postby SlyOwl » Sat Feb 27, 2010 10:40 am
Aliencat wrote:7. Custom minifigures, as well as non-LEGO string and stickers are allowed.
I'm thinking of using some flame pieces with the tabs cut off - is this allowed?
Now, to build the Death Star overnight... somehow! :lol:
SlyOwl
Postby puddleglum » Sat Feb 27, 2010 2:13 pm
Here's a castlefication of the Dino Attack set Urban Avenger vs. Raptor
(Photo is a link to the photoset of 3)
"Nothing wrong with me. Not a frog. Nothing frog with me. I'm a respectabiggle . . . Reshpeckobiggle."
flickr
puddleglum
Postby allweird » Sat Feb 27, 2010 5:51 pm
3th entry:
7595 A twist on the awesome Army Men on Patrol.
photo 1
photo 2
photo 3
And my 4th entry:
8838 The medieval counterpart of a Shock Cycle is... a horse!
photo 1
photo 2
photo 3
allweird
Postby koffiemoc » Sat Feb 27, 2010 6:53 pm
Without knowing that allweird would take the same original set as a starting point, I think I've come up with a different moc though.
Here are my Forest Men on Patrol:
photo=link
obviously a twist on set 7595:
photo=link
I first wanted to make a green set, but as green wheels nor horses do exists in the Lego world, and a strict as possible monocolor policy worked best, I decided to go with brown forestmen. The equipment is maintained including boobytrap detector and high speed "on-air" communication.
pretiumque et causa laboris pixit
koffiemoc
Postby Aliencat » Sat Feb 27, 2010 7:42 pm
Normally I'm against customizing, and so is Blue, but we agreed the tabs from the flame piece are such a minor adjustment, it's no big deal. If you need to cut them off to fit the flames in right, go for it.
Aliencat
Josh's Minion
1620-2 Chocomel Factory
Postby eti » Sat Feb 27, 2010 9:14 pm
Image Image
Click to see 600 px versions.
This is my entry: I turned the Chocomel factory into a brewery - there was no Chocomel (chocolate flavored milk) in the Middle Ages. I had to change a few more things along the way:
I have two extra minifigs. I had to, because there was no electricity, so more manpower is needed. Instead of the streetlight, a boy has to hold up a torch. And somebody needs to manually pull those chains.
There is a quite a lot more vegetation in my version - obvious, there weren't so well groomed streets and sidewalks back then. There are some rocks, too.
The traffic sign is a replaced by a sign that explains that there's a brewery here - in a language that even analphabetics (95% of the population, at least) can read.
The flower stall has become a fruit stall - now who would buy flowers in the Middle Ages? But farmers did come to the city to sell their produce of course.
And the gentleman with the suit and the letter has become a knight with a shield and a sword, obviously. And he walks on the road instead of crossing it.
Two more views from different angles, click to enlarge:
Image Image
On Flickr my main image is larger, but the 600 px version that the main image here links to is of course my official entry.
eti
Postby rbolsius » Sat Feb 27, 2010 11:51 pm
Here is my entry for the Time Twisters Contest: Medieval Corner, a twist on 7641 City Corner.
MEDIEVAL CORNER
Build a corner scene from LEGO Castle! Will the peasant be late for the cart? Will the stable hand get the horse of his dreams? And who gets to enjoy the freshly-brewed ale? It’s all up to you! Build a tavern, stable, and cart with cart stop. Includes 5 minifigures (cart driver, barmaid, stable hand, stableman, and peasant) and accessories! Lots of play opportunity: includes tavern, stable, cart and cart stop! Highly detailed! Working doors and windows, seat the minifigures on the wagon or have them dine at the tavern. Don’t forget to pick up the horse at the stable!
Entry
Original Set
Flickr Set
http://www.flickr.com/photos/14735179@N02/sets/72157623523348730/with/4394045518/
rbolsius
Postby Balamorgineas » Sun Feb 28, 2010 12:14 am
My 3rd entry is Twisted from set# 6444 Outback Airstrip http://www.brickset.com/detail/?set=6444-1
Medieval Airstrip
Here is the Brickshelf Folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422689
My 4th,5th,6th,and 7th entries are all from the Dino Island, Adventurers subtheme
4th entry is twisted from set# 5903 Johnny Thunder and Baby T http://www.brickset.com/detail/?Set=5903-1
Medieval Johnny Thunder
Here is the Brickshelf Folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422693
5th entry is Twisted from set 5912 Mike's Swamp Boat http://www.brickset.com/detail/?Set=5912-1
Medieval Jimmy Blake
Here is the Brickshelf folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422695
6th entry is Twisted from set 5913 Dr Kilroy's Car http://www.brickset.com/detail/?Set=5913-1
Medieval Doctor Kilroy
Here is the Brickshelf Folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422694
7th entry is Twisted from set 5914 Sam Sanister and Baby T http://www.brickset.com/detail/?Set=5914-1
Medieval Sanister Sam
Here is the Brickshelf Folder http://www.brickshelf.com/cgi-bin/gallery.cgi?f=422696
In the last two entries I used some broken helmets but for the most part none of the minifigures were customized.
Thanks for the contest :)
Balamorgineas
Image Image
Balamorgineas
Balamorgineas
PreviousNext
Users browsing this forum: Bing [Bot] and 2 guests
