thanks for fast uploading my Diablo at Fantasy minifig section. But can someone please change the link to that
http://www.flickr.com/photos/gothano76/8291616117/in/set-72157632298845042/
Thanks a lot!
Gothano
ACPin wrote:Bruce N H wrote:Moved to Miscellaneous - entry does not meet minimum category requirements
ACPin-Viking Whaling Outpost - I'm pretty sure this is over the 32x64 or 48x48 footprint.
Bruce,
I used one 16x32 and twelve 8x16 baseplates which all add up to the specified limits for the footprint.
AC
Bruce N H wrote:I'd be happy to do that, but then you'd go back on the naughty list for over large photos. I took the liberty of letting through some entries that only had one photo anyway by deeplinking to the photo of the correct size. Let me know what you'd rather I do.
ACPin wrote:ACPin wrote:Bruce N H wrote:Moved to Miscellaneous - entry does not meet minimum category requirements
Bruce,
AC
Bruce,
I still see my entry in the Miscellaneous category.
AC
All entries should fit on 2 connected 32x32 baseplates or smaller unless stated otherwise in that category's rules. You may use a single 48x48 plate for your entry instead of the two 32x32 plates.
Burlogh wrote:Griffon wrote:It seems my pictures are too large but I had resized them to 600x800 which is the admitted size so I don't see what I have done wrong, please give me guidence.
Same problem here, as I see all my photos are 800*600 but I'm still on the naughty list. Any advice is appreciated.
It seems I am not the only one, how to get it right?
Justin M wrote:Hello Burce,
I thought I posted it to the "An Ill Advised Journey" category but it some how ended up in the "Miscellaneous" category with out the description that I clearly remember putting on when I submitted my entry.
-Justin
Ryclen wrote:For some reason, the description of my Daring Escape entry was cut off, so I'd like to resubmit/replace it with a full description, if that's ok.
Users browsing this forum: Exabot [Bot] and 4 guests
