Is anyone doing any collaborative hill/cliff building? I was planning on building some additional cliff face beyond what I had at BrickFest 2009.
I don't know if anyone else is, but I have built the sigfig shoot hill...well sand dune.
fraslund wrote:My biggest issue I think is the height. I built everything on standard plates...
ffilz wrote:Is anyone doing any collaborative hill/cliff building? I was planning on building some additional cliff face beyond what I had at BrickFest 2009.
Frank
Frank
Frank
Tedward wrote:fraslund wrote:My biggest issue I think is the height. I built everything on standard plates...
All you need to do is add some plates and bricks around the edges. Two plates high right on the edge is enough to create a gentle slope down from the one brick of the adjoining modules.
You do not have to bring the entire surface up to the same height. In fact part of the reason we use this system is to allow different elevations to avoid a flat surface.
If you have run out of green plates and brick someone else can bring theirs and fill in the "gap" (just remember to remove it before you take your stuff home.)
The Blue Knight wrote:I will be back at BrickCon this year.
AK_Brickster wrote:I also can do a couple of 32x32 road sections or something to fill space if you need it. I might build a black and red evil tower too, if I have time. We'll see. Just let me know what you need to fill out your layout
AK_Brickster wrote:OK sounds good. do we need straight sections, T intersections, 90 degree bends....? Let me know. Also, do they need to be tan? I'd rather build in reddish brown, but if they need to be tan, I can pick up some plates with my next bricklink order.
