Landsknecht Sketch
Landsknecht Sketch
Postby E of Alshire » Thu Jan 18, 2007 10:25 pm
Not nearly Rayhawk in quality, but I thought I'd post it anyway.
The fig portrayed uses some custom elements- namely the gorget (chest armor), sleeves, and sword, all peices I've made. On his hip is a plastic cape with a rubber band sash, as seen on Jojo's pirates. I used two of my Landsknecht figs as reference; which will be posted seperately later.
E of Alshire
Postby MaxiVisVires » Fri Jan 19, 2007 1:13 am
Wow, that's pretty good. Any plans on adding color?
Vis Vires Toys | My Brickshelf
MaxiVisVires
Location: San Diego, CA If I was any closer to LEGOLand, I'd be living there
Postby kelderic » Fri Jan 19, 2007 4:02 pm
Very nice, and much better than I could do. Are you planning on adding color?
Kelderic
kelderic
Knight Bannerett
Postby Recluce » Fri Jan 19, 2007 5:26 pm
Very good E! Your technique is better with each drawing we see, and it is getting to be more Rayhawk like. Can you tell us something about how you draw? All digital or do you draw then scan in and trace over? Also, do you have the fig in front of you for a model?
Recluce
Postby E of Alshire » Fri Jan 19, 2007 5:42 pm
MaxiVisVires wrote:Any plans on adding color?
kelderic wrote:Are you planning on adding color?
Anti-aliasing on Paint (the only program I have) is a pain, so probably no. I might color the original and re-scan it, if I find decent paints or markers.
Recluce wrote:Can you tell us something about how you draw? All digital or do you draw then scan in and trace over? Also, do you have the fig in front of you for a model?
I first sketched this out in pencil, then adding thick Sharpie lines. After that, I finished the rest with a thin-line Sharpie, and erased the pencil. I made a few mistakes, and painted over those in Paint, as white-out isn't the same color as the paper I draw on. I missed a few, though, see if you can spot them. :wink:
Yes, I had both figs in front of me. I still didn't quite get the proportions right, but the only apparent mistake is the legs. The knife also came out small.
Thanks for the comments everyone!
E of Alshire
Postby g2 » Fri Jan 26, 2007 2:40 am
This sketch is very good. I would love to see in color. If you have any more please post them.
Thanks for sharing.
g2
Sir Postsalot
Postby Lord Felix » Thu Feb 01, 2007 10:10 pm
Good job. I really like the plume and hat. Great job; doesn't even look like a "sketchy" sketch.
Lord Felix
