Help with Castle or Dwelling roof.
starhorse
Post by starhorse »
Hi all,
I'm trying to create some dwellings for medievil or viking villages. Problem is I don't have a ton of slopes available for the roof. I'm thinking I could use plates, which might actually give the dwellings a nice effect of having a worn look.
I was hoping some of the folks on here might have some suggestions for accomplishing this? It seems that the obvious thing would be to use the 1 x 2 hinge bricks, but perhaps there might be some sturdier options?
Any suggestions would be most appreciated. Thanks.
Post by SavaTheAggie »
Perhaps try a 'floating' roof, wherein you hang a panel or panels of plates, which will make up the roof, where they simply cover the hole between the walls. Connect them where they touch, typically at the roof line, and then hang them on the building.
I found this technique to be quite valuable a number of times. One possible suggestion for what to use are click hinge bricks, connected and angled at 90 degrees. These will make great 45 degree angled plate built roofs.
Norro
Re: Help with Castle or Dwelling roof.
Post by Norro »
I have always liked the 1 x 2 hinge bricks though the old style hinges give great flexibility for degrees...
God Bless,
Nathan
jens
Lord
Post by jens »
Hi!
Do you think about something like this?
regards,
jens
Recluce
Post by Recluce »
THat's a nice looking roof... not a fan of the purple, but would look good in other colors. What exactly is holding those roof plates on? Is it possible to get a pic with one of them off? I'm now intrigued, and it may be good for starhorse, too.
jens
Lord
Post by jens »
Thank you Recluse,
I have the LDraw-File for a closer look:
little_house.mpd
The only picture I can offer is this:
Just klick the little pictures in my postings and you get the bigger version.
The color works very well in the combination with gray and tan. It brings some fantasy style in to the castle-theme.
regards,
jens[/img][/url]
Recluce
Post by Recluce »
Woah! That's ingenious and I'm stealing it. :D With all due credit of course....
Gumby
Post by Gumby »
You can also try using hinge plates (the non-click type), like this:
Page 31 of instruction scan for 6090 Royal Knight's Castle
(ack, I can't get an image from the Peeron instruction library to show)
-Bryan
starhorse
Post by starhorse »
Wow, thanks for the great tips. I love that purple roof construction. Unfortunately it seems a bit over my head right now. I'm still getting back into Lego, and a lot of this stuff is a bit intimidating - I have to be honest. I guess I can start small with some of the more basic ideas until i've improved.
Lord Mikal
Post by Lord Mikal »
Majisto's roof is nice if you have the right pieces.
The yellow roof at the top of this page is atached using two technic 2x1s and a pin.
Gumby's idea works well at large scale, too: http://www.brickshelf.com/cgi-bin/gallery.cgi?i=718179
[url=http://www.brickshelf.com/cgi-bin/gallery.cgi?m=mikal1]My Brickshelf[/url]
Azure, a saltire cantoned with a star in chief and in base and two crescents addorsed in the flanks, argent.
Athos
Councilor of the Realm
Post by Athos »
Roofs... rooves... roofes... The roof is always the hardest part for me to build (and apparently spell), but here's a couple of one's I've done.
Here's one way to do it, not Castle, but the principle is the same:
http://www.brickshelf.com/gallery/Athos ... /gs005.jpg
Here's two others, the light is really bad, but you get the idea:
http://www.brickshelf.com/gallery/Athos ... house1.jpg
http://www.brickshelf.com/gallery/Athos ... house2.jpg
starhorse
Post by starhorse »
I like the way those are done. I think I should be able to emulate that easy enough. I appreciate all the suggestions and pics to go along with them. Thanks!
