Check out the standard here:
http://www.classic-castle.com/ccc/farmstandard.html
Please post your suggestions to improve the standard in this thread. Thanks!
JoshWedin wrote:Hey Ben,
Impressive job on the farm standard, it is deceptively simple.After reading the 'rules', my first thought was, "This can't work, its not complex enough". But I can't find any loopholes that would mess it up. Excellent job!
architect wrote:Thanks Josh! The only hard parts I can think of right now is putting curved roads/paths through or near the farms. We will test this out at BrickFest and see how well it works.
Connecting the farms could be done with corner field marker stones such as grey round 2x2 plates.
footsteps wrote:For roads/paths, keep using the "multiple of 8" principle. Roads are 8-wide on plates or baseplates that are some multiple of 8. When a road reaches an edge, there must be some multiple of 8 studs (or zero studs if the edge is only 8 wide) on either side of the road.
Thus, an 8x16 plate could have a road the goes straight along the length, or cuts across the width with an 8x8 field portion next to it.
On 16x16 or larger baseplates, the road can wander wherever it likes withing the baseplate, as long as its entrance/exit on an edge leaves multiples of 8 (or zero) on either side.
A bend in the road can be made on as small as an 8x8 plate.
Overall, I think the "standard" of multiples of eight is inspired. Having 8x8 or 8x16 patches of field means that there is little or no chance of blank spots. A small rocky hillock can quickly be made to fill any gaps in a display. Hmmm, I'm already getting some ideas for small non-tilled segments of field.
architect wrote:footsteps wrote:For roads/paths, keep using the "multiple of 8" principle. Roads are 8-wide on plates or baseplates that are some multiple of 8. When a road reaches an edge, there must be some multiple of 8 studs (or zero studs if the edge is only 8 wide) on either side of the road.
Your road ideas are good. As long as it is in a mutiple of eight at the edge, arranging a road should be possible.
Traveler wrote:This is a great idea. It should really help move castle displays in an even more realistic direction, as an actual town would be surrounded by supporting fields of crops. My question is, will the farm display be integrated into a town using the CCC standard? If so, it would neeed to be carefully planned to match up with the size of the outer wall of the city.
Good thinking!
Or make paths 4 wide down an edge of a baseplate. Roads are then two abutting paths
I think that it is cool that you are trying to get people with little collections (like me) into the larger MOC world.
Stone Goblin and I use baseplates, but we elevate the overall height by a brick and then apply plates. We do this so that we can put 2x1 technic bricks on corners, 2 studs away from the edge so we can keep things locked together. If you plan for it, you can add sink holes and ponds, and you can always build higher.
Users browsing this forum: Exabot [Bot], PsychoPixie and 16 guests
