Castle Chess Set $10 Off in US
- The Trojan Rabbit
- Peasant
I was reluctant about buying this set at this price, and from what I can see..I hope they drop to 25$ so I can buy more. The set is great, NOTHING is glued, not even the board. You get a good selection of minifigs, that are found in the other more expensive sets. My advice pick one up before they're gone.
- Tower of Iron Will
- Master
I broke down and ordered one when buying some of the Castle battle packs. I didn't want to miss this either, but I had purchased some of the Viking chess set. I can't wait for the super chess set.
- Crazylegoman
Mine had a very slight amount of glue holding the 4X4 plates on the board. It looked like they had brushed on a tiny thin film of glue between each row of studs. The plates, however, were very easy to remove, and the board still looked pretty good.The Trojan Rabbit wrote:The set is great, NOTHING is glued, not even the board.
David
♪ "Whether I'm the last one alive, or ascend before my time
Better I'm the last one alive, than a soul denied" ♫ —Demon Hunter
- Blue Monarch
Oh good! I'm glad I'm not the only one with glued tiles. I might have to try to pry it apart.Crazylegoman wrote:Mine had a very slight amount of glue holding the 4X4 plates on the board. It looked like they had brushed on a tiny thin film of glue between each row of studs. The plates, however, were very easy to remove, and the board still looked pretty good.The Trojan Rabbit wrote:The set is great, NOTHING is glued, not even the board.
David
The term "Hobby" allows you to explain to your relatives why you still play with toys...
