Why isn't my CCC entry moderated yet? - Final listing
Postby Bruce N H » Tue Nov 27, 2007 1:40 pm
Here's the thread to answer that question that comes up every year at this time, "Why isn't my CCC entry moderated yet?" Often the answer is simple patience. We're getting to them, but the admins aren't necessarily checking the entries each day, and certainly not multiple times in a day. So if you wait 24 hours your question may be answered. In other cases, though, there may be a violation of the rules. In order to prevent problems down the road, we're trying to be strict about adherence to these. Periodically the admins will post a listing in this thread of which entries are not in compliance.
Problem entries, December 9th
Broken link - Please provide the correct link.
-none at this time-
Oversized pictures - please resize the pictures and let us know and we will authorize the entry
Stephen - 2 entries - Blacksmith Shop and Royal Knights Battle
Thomas (Remyth) - 3 entries - coronation, swamp, coal mine (Yes, Flickr does an automatic resize, but if you click on "all sizes" you get larger pics.)
Athos - Cheese Roll
jesusismyhero - 2 entries - Pilgrimage to the Celtic Cross, Medievil Farm
Sir Nadroj - 6 entries - Bakery and Mill, Slayed Dragon Festival, Falcon's Journey, Farm and Barn, Snow White's Escape, The Black Plague
Too many images - Please delete all but your favorite three images. It's fine to have a separate folder elsewhere to show off your MOC, but we only want to judge based on three pictures.
Mastergongfu - Road Side Farm
Footprint violation - Your MOC must sit on two connected 32x32 baseplates or one 48x48 baseplate, or smaller, in all but the "misc" category. There is no size restriction on the "misc" category.
-none at this time-
Category violations - MOCs that somehow do not fit the category under which they were entered. Please fix, or ask us to shift these to "miscellaneous".
Peter - Royal Knights Throne Room - This isn't really two rooms, as described under the "castle spaces" description ("Build two or more connected castle spaces"). This is a bit of a judgement call, as there is an undeveloped area beyond that archway that could be called a second room, so let us get back to you on this.
Thanks,
Postby Bruce N H » Wed Dec 05, 2007 11:27 am
Problem entries, December 5
-none at this time-
Jesusismyhero - 2 entries - farm and pilgrimage
drummer - siege tower
athos - cheese chase - Steve, your third pic is too big.
webrain - renaissance fair - Your last image is a composite of many images. In the past we have only allowed composite images to show an "action feature" (e.g. trap door open and closed). Please replace this with a single image.
-none at this time-
Other rules
MrTS May Day - still awaiting ruling on non-LEGO string
Postby Bruce N H » Thu Dec 13, 2007 7:32 am
Problem entries, December 13
-none at this time-
jesusismyhero - 2 entries - Assyrians flood Babylon and Victory Celebration. BTW, we switched the "Assyrians flood Babylon" entry into "misc" as it was over 1000 years too early for the stated timeframe (fall of Rome to great fire of London), but if we just think of this as a random siege it could go in misc.
Mastergongfu - farm - You have 5 images.
Too many images - Composite images Composite images are only allowed in very specific circumstances (i.e. showing how some "action feature" works, such as a trap door open and closed). Please replace the composite image with a single photograph.
Maciej Koszyka - bakery - third image is composite
Kelderic - farm - third image is composite
-none at this time-
-none at this time, aside from the "Assyrians flood Babylon" entry discussed above.
Other rules
-none at this time-
Postby Bruce N H » Fri Dec 21, 2007 12:47 pm
Problem entries, December 21
nikopt - snow journey - the link you provided goes to an empty brickshelf folder
wojtek - Viking journey
Lord Doom - evil alliance - You have three other images in the folder you link to that like you intend to be an entry in the industry category. Please make a separate folder for each entry with only three images in each folder. Thanks.
Maciej Koszyka - mountain mine - third image is composite
-none at this time-
- the "Assyrians flood Babylon" entry discussed above was switched into misc
Rolf - Your Viking Spike entry doesn't fit into the category rules. In this category you were asked to show the process of fortifying, with before and after (and maybe during) pictures. The fortress you showed is "after". Either add a "before", or else we can just switch this fortress into the miscellaneous category. Let us know which you prefer.
Also, Piglet, I switched your medieval submarine into the misc category. Let me know if this is a problem and we'll talk.
Postby Bruce N H » Mon Dec 24, 2007 10:46 am
Problem entries, December 24
LEGO-las - Evil Mountain Shaman - In addition to the large images, we've already discussed the prominent use of clone brand parts.
slyowl - cheddar gorge - Sorry, I really appreciate the work you did to pick out all of the details to make the composite images, but we're not letting others do this, so please give us single images.
stambi - byliny
stambi - trieria - Also, this is in the "historic" category, which has a timeframe of 476-1666 AD, but you've got a MOC from the 200's. I'll have to shift this to "misc".
-none at this time-
BaronSat - Your Fortified City doesn't fit the fortifications category, which is about the process of fortifying. The rules call for "before" and "after" images. Either add a "before", or else we can just switch this into "miscellaneous". Also, there are too many pictures in the folder - limit is three.
Postby Athos » Wed Dec 26, 2007 10:10 pm
Should we let you know when we've fixed the problem? Or do you check the entries to see?
Either way, mine is now fixed.
Athos
Councilor of the Realm
Postby Bruce N H » Wed Dec 26, 2007 10:21 pm
Letting me know, either by PM or in this thread, would accelerate matters. Otherwise I'll check eventually.
Postby hopeso009 » Wed Dec 26, 2007 11:27 pm
Hi Bruce,
I had submitted an entry last night
If you don't mind, pls check to see if it is OK or not.
and Let me know if not OK.
Many many Thanks
hopeso009
Postby Bruce N H » Thu Dec 27, 2007 12:02 am
hopeso009 wrote:If you don't mind, pls check to see if it is OK or not.
If your MOC shows up when you click when you go to view the entries, that means it's okay. If it is not okay, I will post a notice in this thread, and eventually follow up with an e-mail now that we're getting near the deadline.
In your case, your farm entry was already authorized.
Postby hopeso009 » Thu Dec 27, 2007 12:17 am
Thanks Bruce
for your quick response..
hopeso009
Postby Bruce N H » Thu Dec 27, 2007 3:32 am
Problem entries, December 26
Mastergongfu - farm - 2nd and 3rd images too large
-none at this time, except the composite images discussed below
stambi - byliny
-none at this time-
Postby Piotr » Sun Dec 30, 2007 5:09 am
Hello Bruce!!
Why my MOC (,,The Last Adventure") isn't moderated yet?
I had submitted an entry at 4:50 P.M. last day.
"Atra esterni ono thelduin."
My MOCs
Piotr
Postby architect » Sun Dec 30, 2007 8:38 am
Piotr wrote:Hello Bruce!!
Hi Piotr,
It may take the admins several days to approve an entry once it has been submitted.
Postby matthew444442 » Mon Dec 31, 2007 2:07 am
Why my entry - Crusader free time & Medival bridge isn't moderated yet ?
matthew444442
Postby Mateusz » Mon Dec 31, 2007 5:36 am
Where are my two work? Yesterday they have been reported ok. Hour 22:15.
Mateusz
Users browsing this forum: Rifiröfi and 2 guests
