Hello,
I'm building my entry for the contest and I'm trying to build a small cross to put on the altar.
I've tried many ways but the result is always awful.
Does anybody has any advice or some good examples to... copy ?
Thanks
Try using a coin in the centre of 4 gear stick bases (like here(also the crosses on the outside, made of technic angle connectors). Also, a 1x1 tile/plate with 4 clips around it works (like here).
I'm late to the game, but this is a simple solution (here in a MOC by TaltosVT):
The key is a 1x1 brick with studs on all sides in the center:
with a 1x1 tile to cover the extra stud. Or now you could use the 1x1 brick with studs on two sides:
for an even simpler cross.
