It is irregular on one of the sides, it ends up to roughly be around 70 x 70 studs, and is my third largest build! As I have said before, this took me two and a half months of on and off building. Overall, I think I worked on it for around 75 hours...
Anyways, now for the exciting part:
[img]http://images.moc-pages.com/user_images/127 ... SPLASH.jpg[/img]
[img]http://images.mocpages.com/user_images/1271 ... SPLASH.jpg[/img]
The bridge definitely took the longest to complete, and it was what I started the build doing. The arches took me a couple tries to find, but I ended up doing the illegal technique with headlight bricks connecting front to back to create a gentle curve that worked great here IMO. After figuring out the arches, I began looking at a couple different stonework techniques by great builders all over, I still couldn't find one that fit the look of the inspiration picture I was looking at, so I decided I would make up my own technique, as you can see it is just simple SNOTed tiles with gaps to give it a little dimension. Next I started to build the watermill itself and continued the same stonework style with it. I used the generic tudor style for the build, and put a straw roof on top, which proved quite difficult because of the angles. Next it was on to landscape, where I did your average landscaping, and then covered it with plant leaves like my previous Hobbiton build. Then on to the water, which is trans. clear over different shades of blue.
I will be competing in the CCC this year, so expect some builds coming in a little quicker than usual.
For the WIP journey, and a few more pictures click here: [url]http://www.moc-pages.com/moc.php/442699[/url] Please drop a like and a comment!
C&C Appreciated!
I hope you enjoyed!
To God be the glory!
