A new article has been added to our How-To section. Feel free to check it out.
Feedback on any article is always appreciated.
Dan_BL wrote:Have just one question about photoshop and custom torsos:
How do you print several pictures of a torso design on the same piece of paper. For example, were I to print one of your PSDs, I would practically waste all my paper except for the little torso in the middle of it. Is there a special or specific way I can "Ctrl-C" everything and enlargen my canvas so it fits just right on a printed sheet of paper?
Thanks
Dan
TwoTonic Knight wrote:
On the toobar, select Image, Resize, Image Size. Set image size to inches and then fill in the numbers. I usually use 8 x 10.5 (without going into full bleed and normal printer limits, that's probably a safe number).
Now just open whatever image you want, magic wand it if you know what you are doing, or just the rectangular selection tool as appropriate, select copy open or select the large 8x10whatever image and paste. Select the move tool and drag the transfered image to where you want. Be prepared to learn how to manipulate layers, or at least flatten them if you find yourself getting confused.
