Hi there,
my friend back at
Kostky.org, the Czech Lego Forum has notified me that you discuss my creation here. I am very glad you guys here noticed it and thanks for all the comments.
This is my first big MOC + it is in progress so it lacks a lot of things. Your comments are spot on:
1) the rocks do not look realistic - this will be done later when i fine-tune the details. For now i just need to fix the base (size + shape)
2) the gatehouse needed a little work as it was too tall for the small rock it was built upon. So i extended the 'rock base' + added side supports. Now looks more robust and balanced, i think
3) Average look - yep for the moment (as i am in the beginning of construction), but let's wait for the finished product
On the other hand, most of the castles i've seen on brickshelf are similar (dark gray rock base, gatehouse, light gray castle). But i'll try to spice it up with detail.
4) Size - the proportion of the gate and the main castle was not balanced, so i extended the 'rock base'. I need to do futher extension to get more space inside the keep
I already did some modifications yesterday, so check out
my gallery (pls skip the lame old creations
) and let me know what you think of it.
thx
